Engine Mechanical problem
1992 Honda Civic 4 cyl Front Wheel Drive Manual
my single point injection engine d15b2 has blown. i have a second hand d15b2 but is carbourated.
The hole where the fuel pump can be blocked easily but will it still run due to the timin could be diferent. Not sure if if cams etc will be the same, dont wont to put it in if there is a chance they are not set to run the same. Both are d15b2 engines. honda civic k reg 1493cc lsi
Mar 23, 2009 at 7:38 AM
