1992 Honda Civic clutch problems
203,000 MILES • 4 CYL • FWD • MANUAL
~CAROLLO~
i have a 92 honda civic lx 4 dr Manuel i just replaced the clutch and it wont engage we bled the slave cylinder line and gave up for the night
what could be wrong with it??
Sep 25, 2010 at 1:43 PM
KHLOW2008
  • 41,812 POSTS
Hi Carollo,
Are you getting any pedal pressure?
Sep 26, 2010 at 2:22 AM
~CAROLLO~
yeah and its not engaging at all
last night it engaged into reverse and i backed
it into the yard and it stoped engaging
today we relized someone drained the tranny fluid by mistake so we tryed that and it still didnt engage but we think something might have went
wrong with the throttle bearing arm when we put the tranny in one of us was holding it but released it when it was on idk if that affected the the wire part hooked to the little ball joint that slides into the wire snap on part hooked to the arm so were thinking about taking it back apart
and pulling out the tranny to fix it??
Sep 26, 2010 at 5:40 AM
KHLOW2008
  • 41,812 POSTS
Check the clutch bearing release lever and slave cylinder to see if the slave cylinder push rod is fully or almost fully extended. That would indicate the clutch bearing has been dislodged.
Remove the slave cylinder and the clutch bearing lever dust cover and use a torch light to look into the bell housing to see fi the bearing has been dislodged.
If yes, you would heve to drop the trans again to reseat the bearing.
Take note never to touch or hold the lever while lining up and installing the transmission.
Sep 26, 2010 at 5:56 AM
~CAROLLO~
its droped
clutch is off again
Sep 26, 2010 at 7:14 AM
KHLOW2008
  • 41,812 POSTS
Too bad you had to repeat the work.
Have a nice day.
Sep 27, 2010 at 5:53 AM
~CAROLLO~
clutch has been done since last night
the axles wernt in all the way
have a good one
Sep 27, 2010 at 12:24 PM
