HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Ignition
Plug Wire
Replace/Remove
1991 Honda Civic
MANUEL1010
MEMBER
1991 HONDA CIVIC
Engine Performance problem
1991 Honda Civic 4 cyl Two Wheel Drive Manual
I have changed sparks plugs, cables ignition rotor, ignition coil, distributor cap, distributor, and still misfires I dont know what else to do
Tuesday, July 27th, 2010 AT 4:41 PM
MECHANIC
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
12. Engine compression problem
Tuesday, July 27th, 2010 AT 5:38 PM
Please
login
or
register
to post a reply.
Related Plug Wire Replace/Remove Content
2004 Honda Civic Spark Plug & Wire Change
Dear Sir Or Madame, I Have A 2004 Civic Si, 1.7 Litre Engine. I Would Appreciate A Little Advice. I Just Want To Change The Plugs & Wires...
Asked by
Cal.A
2004
HONDA CIVIC
Car Was Running Accidentally Pulled Out Number 3and...
Car Was Running Accidentally Pulled Out Number 3and Spark Plug Wire While Car Was Running I Plugged It Back In Car Died And Now It Wont...
Asked by
jem1
2000
HONDA CIVIC
1991 Honda Civic Spark Plug Question
1991 Civic 4 Door Sedan With 182,000 Miles. I Pulled The Spark Plug Wires Off The Spark Plugs To Check Them. The Spark Plugs Are Deep...
Asked by
Grgry
1991
HONDA CIVIC
1991 Honda Civic Oil On One Spark Plug
How Easy Is It To Chage The Seals For The Spark Plug Well And Will I Have To Mess With The Timing Chain If I Try To Fix It Myself?
Asked by
jarodriguez
1 ANSWER
1991
HONDA CIVIC
1991 Honda Civic Distributor
I Recently Begin Hearing A Loud Screech Or Grinding Coming From My Distributor. After Speaking With My Father He Mentioned That The Shaft...
Asked by
cjgreene
1 ANSWER
1991
HONDA CIVIC
VIEW MORE
Misfire
Intermittent Misfire
Misfire Random Code P0300
