1991 Honda Civic oil on one spark plug
JARODRIGUEZ
  • 1991 HONDA CIVIC
  • 4 CYL
  • MANUAL
  • 150,000 MILES
How easy is it to chage the seals for the spark plug well and will I have to mess with the timing chain if I try to fix it myself?
Monday, August 25th, 2008 AT 7:37 AM
2CARPRO JACK
  • 11,533 POSTS
Are you sure it isnt the top seals in the valve cover, If so it is easy fix. Get an entire valve cover gasket set, should have 4 round seals to replace for your problem, no you dont have to mess with the timing belt to fix it
Monday, August 25th, 2008 AT 7:44 AM
