I recently begin hearing a loud screech or grinding coming from my distributor. After speaking with my father he mentioned that the shaft that spins the rotor may not be receiving oil from the valve cover and will make such a sound. As such, he recommended I apply a small bit of oil to the shaft and see if the noise goes away. After I completed this the noise did disappear. Further, he mentioned wherever the oil gets into the distributor might be clogged and as such the shaft is not receiving oil. Does this sound accurate and if so where does the oil come into the distributor from the valve head? Can I simply take off the distributor and clean up the area and unplugged the port (if that is how this works, I am unsure)? Thank you for your help.
Jan 28, 2009 at 1:14 AM
