1989 Honda Civic timing belt replacement
MREEVES
  • 1989 HONDA CIVIC
  • 4 CYL
  • MANUAL
  • 205,000 MILES
I need to replace my timing belt--each time I have done this in the past, I have had a horrible time removing the crankshaft pulley. In removing the bolt for the pulley, the clutch slips and it cannot be removed without resorting to air wrenches. A friend told me a quick solution for this is to use a break bar socket wrench and place it on the bolt, then strap the breaker bar to the frame, then kick the engine with the starter--the revolution of the engine would loosen the bolt. Is this a wise solution?
Wednesday, May 7th, 2008 AT 4:25 AM
  • 31,937 POSTS
Hi there,
I would remove the starter and lock the ring gear with a large screw driver or a pinch bar,
this other method is dangerous and serious personal injury could occur. Don't do it this way.
Mark (mhpautos)
Wednesday, May 7th, 2008 AT 4:31 AM
PEAR69
  • 1,482 POSTS
NEVER use the power of any internaly combusted engine to remove anything--especialy the crank pully bolt! The engine can easily shatter the socket and/or breaker bar into little flying missiles. There are many reasons for the use of air impact tools--- this is one of them. Please don't do it----
Wednesday, May 7th, 2008 AT 4:38 AM
