Electrical problem
1989 Honda Civic 4 cyl Front Wheel Drive Manual 130k miles
engine will not start. Brand new battery. Not cranking. I can here relay click below dashboard.
Wednesday, January 9th, 2008 AT 4:43 PM
MECHANIC
Hi there,
Check if voltage is at the starter solenoid terminal when cranking, if not check the starter relay, if power at solenoid, check battery terminals are clean and tight and 12 V at main starter terminal, if so starter is faulty.
