1991 Honda Accord White Exhaust Smoke
JERZ2STL
I have a 91 Honda Accord LX that has 250K miles on it. As I accelerate I see white smoke from the exhaust, but none at normal speeds. The oil is not milky and the radiator fluid is not discolored or low. The car runs smooth no sputtering or missing at all. I replaced the plugs and changed the oil, I also added some "sea foam" to the engine oil and gas tank. Car ran even quieter but still see the white smoke every time I hit the gas hard and it disappears when normal driving. Is there any other thing I should look for i.e. change from regular unleaded to premium?
Thanks
Brett
Jul 26, 2007 at 3:01 AM
BRUCE HUNT
  • 3,754 POSTS
Keep a good check on the radiator coolant level. I suspect that it might very slowly be dropping. You could have a leak down test performed on the engine. It might point to a head gasket failing.
Jul 26, 2007 at 4:58 AM
Suggested Repair
Monitor the radiator coolant level for a slow drop and have a leak-down test performed, which may indicate a failing head gasket.
Conversation Summary
A 1991 Honda Accord with 250,000 miles produces white exhaust smoke only under hard acceleration, not at normal speeds. The oil is not milky, coolant is not discolored or low, and the engine runs smoothly. Plugs, oil, and Sea Foam did not stop the smoke. The expert advises watching the coolant level and performing a leak-down test, which may point to a failing head gasket.
