1995 Honda Accord Speedometer Failure
CASANOVA
The other day I was driving and I my speedometer starting going haywire. It would go up and down then the car started jerking alittle bit. Well the car has stopped jerking and my odometer and speedometer doesn't work at all. My question is I bought a new VSS and I'm planning on installing it today. But!! Sometimes while I'm driving it the speedometer moves and it will tell me how fast I'm going and the odometer starts moving too. The check engine light will pop on when either meters aren't working but it'll shut off when it starts moving again. What is going on? Should I change the VSS with my car being so old or do I have a faulty wire problem? Its a 95 Honda Accord DX. If I install the VSS should this problem go away? Will my speedometer and odometer start working again? Or will I have to re-wire the whole sensor?
Apr 20, 2006 at 11:57 PM
LOSONE
  • 1,616 POSTS
Back to basics!! Have someone use a scanner and check what codes are present. Don't replace anything until you find out what is causing the problem. It is kind of like shooting at a target in a dark room. Good luck
Apr 21, 2006 at 5:26 AM
Suggested Repair
Have the vehicle scanned for diagnostic trouble codes before replacing the VSS or any wiring. Do not replace parts until the cause is identified.
Conversation Summary
The owner of a 1995 Honda Accord DX reports an intermittent speedometer and odometer that sometimes work and sometimes fail, with brief jerking and a check engine light that comes on when the gauges stop. They bought a new vehicle speed sensor and asked whether installing it would fix the problem or if wiring is at fault. The expert advised scanning for codes first and not replacing anything until the cause is known.
