I replaced the vss on my 97 accord but the speedometer still doesnt it work ?
Thursday, March 4th, 2010 AT 5:36 PM
BLUELIGHTNIN6
MECHANIC
Could be bad instrument cluster or wiring to the cluster
SPONSORED LINKS
Thursday, March 4th, 2010 AT 5:37 PM
JJMAN517
MEMBER
The wires have power and the sensor is new changed it twice any idea please help truly stumped?
Thursday, March 4th, 2010 AT 5:40 PM
BLUELIGHTNIN6
MECHANIC
Just because wires have power doesn't mean the circuit board on the back of the gauge cluster assembly is good. The circuit to the speedo could have burnt out and if so the entire cluster will need replaced
Thursday, March 4th, 2010 AT 5:41 PM
JJMAN517
MEMBER
A little lost can u put it in easier terms looking this up for my boyfriend?
Thursday, March 4th, 2010 AT 5:48 PM
BLUELIGHTNIN6
MECHANIC
You know the part that contains all of the gauges? Speedometer, odometer, water temp. Etc. That assembly has electrical parts on the back of it called a circuit board. Part of that board may be bad and preventing the speedometer to work. The entire gauge assembly will need replaced if thats the case.
