1989 Honda Accord No Vent Airflow
HEIDIURBAN
the other day all air flow from my vents stopped working? Is there a fuse that just needs to be replaced or is it something much bigger than that? My car is a 1989 Honda Accord with 397000 kms. Could it maybe just be that the car is just dying?! Thanks so much.
Dec 11, 2006 at 4:16 AM
BRUCE HUNT
  • 3,754 POSTS
Does the circulation fan still work? I would look at the knob to ensure it engages and is not slipping and then I would look at the linkage that selects air direction from the heater plenum.
Dec 11, 2006 at 12:09 PM
HEIDIURBAN
The circulation fan doesn't work? There is no air flow whatsoever. Thanks.
Heidi
Dec 12, 2006 at 6:04 AM
BRUCE HUNT
  • 3,754 POSTS
Fan is not working. Look at the fan fuse.
Dec 12, 2006 at 6:17 AM
HEIDIURBAN
I've looked in my owners manual to try and see which fuses are which but it doesn't tell me. How do I know which fuse to change? Thanks.
heidi
Dec 12, 2006 at 6:53 AM
BRUCE HUNT
  • 3,754 POSTS
First find the fuse locations. There are fuses either under the dash on the driver side or on the end or ends of the dash by the door. There are also fuses under the hood in the engine compartment.
When you pull off the cover there will be a diagram of the fuses and the basics of what they are for. Now that does not make it any easier. But as a last resort, pull out everyone and inspect it. When you find the culprit, replace it with a fuse of the same amperage.
Dec 12, 2006 at 8:19 AM
HEIDIURBAN
Thank you so much I will try that and see if it works. I mean I don't expect much from my car because she's so old but I only hope shes lasts another 100 000!!! Thanks again, I really appreciate all your help.
Heidi
Dec 12, 2006 at 11:16 AM
Suggested Repair
Locate the blower fan fuse under the dash or in the engine compartment using the fuse-box diagram. Inspect the fuses and replace any blown fuse with one of the same amperage. Also confirm the fan control knob engages and is not slipping.
Conversation Summary
The owner of a 1989 Honda Accord reported that all vent airflow stopped and confirmed the circulation fan does not run. The expert advised checking the fan fuse, locating the fuse boxes under the dash or hood, using the cover diagram, and replacing a blown fuse with the same amperage. The owner planned to try that.
