my ac on my 1992 honda accord is not turning on. there is no air coming out. what could be causing this?
Jul 12, 2007 at 8:20 AM
Check the blower fan fuse and any fan relay. If those are good, apply 12 volts directly to the fan to see whether the blower motor runs.
The owner of a 1992 Honda Accord reports that the A/C does not turn on and no air comes from the vents. Nothing happens when the fan switch is turned, although something can be heard when the A/C button is pressed. The expert suggests checking the fan fuse and possible fan relay, then testing the fan by wiring it directly to 12 volts.
