The eratic idle is caused by either the idle air controller or a sticking EGR valve.
All you need is flat head screwdriver, socket set, 8" C clamp, impact driver with phillips bit.
Put car up in air. Take wheel off. Take 2 bolts out that hold caliper on. Use screwdriver to pry caliper off. Sit aside. Pull brake shoes off caliper mount. 2 17mm bolts on back side holdin caliper mount on, take those out. If your car still has, or does have 2 phillips head screws holdin rotor on than those have to come out and sometimes there a bitch. Penetrating fluid first, than id heat them up just with a simple propane torch will do. When there hot, whack where your wheel mates with the rotor on top of those screws to loosen there grip some. Use impact driver to take them out, screwdriver may work. Once you get rotor off clean(new rotor) real good with brakeclean, stick it on. Put caliper mount back on. Place new brake shoes in holders. Use a C clamp to depress brake caliper piston (some hondas have what looks like a big flat headed screw for a piston, if yours does than all you have to do is turn it cloclwise and it winds itself in). Be careful not to damage rubber seal around piston and that it seats back in place properly. Sit caliper back over shoes and mount. Grease your sliders(caliper bolts) with white lithium grease I recommend and stick them back in and there one side is done. Never overtighten bolts. Very snug but not with all your might. When you get new front brakes on your pedal might feel funny(not much there) for first day or so. Start car up when done and keep pumpin pedal to work the slack out. No need for bleeding or nothin as well to let you know.
Good luck
SPONSORED LINKS
Saturday, April 15th, 2006 AT 12:54 PM
