1996 Honda Accord Brake Pedal Sinks
GOURMET1
I have 1996 honda accord a 2.7v6 engine automatic
transmisson 138122 mileage I has trouble with
brake pedal bleed down with engine on of off I check master cylinder in is fill
Oct 4, 2007 at 11:36 AM
  • 31,937 POSTS
Hi there,
It sounds like your brake master cylinder is by passing fluid internally. What happens is that one of the pressure cup may have failed and as you apply pressure the fluid is passing the cup and returning to the reservoir, so there is no visible fluid loss and poor pedal pressure results. A new master cylinder is the answer.
Mark (mhpautos)
Oct 4, 2007 at 11:57 AM
Suggested Repair
Replace the brake master cylinder. A failed pressure cup can let fluid bypass internally back to the reservoir, so the pedal sinks with no visible fluid loss.
Conversation Summary
The owner of a 1996 Honda Accord with a 2.7 V6 and automatic transmission reports the brake pedal bleeds down with the engine on or off, while the master cylinder remains full. The expert says a failed pressure cup is likely bypassing fluid internally back to the reservoir and recommends a new master cylinder.
