1989 Honda Accord Sunroof Motor Location
DORATHEEXPLORER
  • 46 POSTS
I have an '89 Accord. Can someone please tell me where the motor is located for the sunroof? Also if there is a fuse involved & where it is located. I've looked in the roof & it's not there.
Jul 18, 2006 at 2:54 AM
BRUCE HUNT
  • 3,754 POSTS
The motor has to be in the roof and there are fuses. Check out the owner manual. The fuse could be under the hood.
Jul 20, 2006 at 8:57 AM
DORATHEEXPLORER
  • 46 POSTS
Thanks. I don't have an owner's manual, only a Hanes & it doesn't really tell you much. I'll look in the roof again, but the only thing I've seen up there are the guides. I've also checked the fuse box under the driver's side & there's nothing there for the sunroof. I'll check under the hood. Thanks again.
Jul 20, 2006 at 9:06 AM
BRUCE HUNT
  • 3,754 POSTS
there is a place on the roof where you insert a tool to close the sunroof and I believe that is the motor being turned by the wrench. There is a popout plug covering the hole for the wrench.
Jul 20, 2006 at 9:14 AM
DORATHEEXPLORER
  • 46 POSTS
WOW. You are absolutely correct. It looks like an allenwrench would work. Now, I just need to find the fuse. Thanks a million! If it's broken it sure doesn't look easy to get outta there.
Jul 20, 2006 at 9:32 AM
Suggested Repair
The sunroof motor is in the roof behind a pop-out plug. Use an Allen wrench in that opening to turn the motor and close the sunroof. Check the under-hood fuse box and the owner's manual for the sunroof fuse; it was not found in the driver's-side interior fuse box.
Conversation Summary
The owner of a 1989 Honda Accord asked where the sunroof motor and fuse are located after not finding the motor in the roof. An expert said the motor is in the roof, that fuses exist and may be under the hood, and recommended the owner's manual. The owner had only a Haynes manual and found no sunroof fuse in the driver's-side box. The expert then identified a pop-out plug covering a wrench point used to turn the motor and close the sunroof. The owner confirmed an Allen wrench appears to fit and still needed the fuse location.
