1998 Honda Accord Slipping Clutch
KAYCEE121700
I have a 1998 honda accord 4 dr 5spd 4clydr. with a 100,000 miles on it. I am having trouble accelerating. I dont know if it is my tranny or what. but when i put it into gears it is like its just reving. like it is in nuetral. It start going after 4000 rpm or so. but it still having problem accelerating. it does this in all gears. im hoping is a minor repair. but can u guys tell me what the possible problem. and what i can do to fix it. thanks very much
May 28, 2007 at 6:24 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the clutch is slipping. 100K, not too bad. When you get your new one , be sure they install NEW clutch disc, pressure plate, throw-out bearing and pilot bearing(if applicable) some Hondas dont ahve the pilot brng. Dont let them talk you into remanufactured parts for less money, not worth it.
Jun 9, 2007 at 1:58 AM
Suggested Repair
The symptoms point to a slipping clutch. Replace the clutch with new parts: clutch disc, pressure plate, throw-out bearing, and pilot bearing if the vehicle has one. Avoid remanufactured clutch parts.
Conversation Summary
The owner of a 1998 Honda Accord with a 5-speed manual and about 100,000 miles reports poor acceleration in all gears. The engine revs as if in neutral and only begins to move the car around 4,000 rpm. The expert says the clutch is slipping and recommends installing a new clutch disc, pressure plate, throw-out bearing, and pilot bearing if applicable, rather than remanufactured parts.
