1992 Honda Accord Sputters When Warm
ZACHTHOMAS20
Hi -
I have a 92 Honda Accord EX with approx. 140,000 miles. motor sputters - most noticeably at idle, then gets less noticeable as RPM's climb. Obviously this negatively affects performance in general but curiously, as the car warms up, performance gets worse. Once the motor hits normal operating temperature, car starts bogging down badly at low RPM's. Only when revs pass 3000 RPM's does the motor seem to "wake up", but even then there is still a noticeable lack of power. Changed the spark plugs/wires but there was no noticeable improvement. Paid $100 for fuel system cleaning at auto shop and there was a small improvement, however, all the symptoms are still present just not quite as severe. Any advice is much appreciated!
Apr 13, 2006 at 1:41 PM
BRUCE HUNT
  • 3,754 POSTS
How about the distributor cap and rotor. Another thing I would look at is the timing. After that without a warning or CEL I wonder about the converter. What do you think losone?
Apr 13, 2006 at 3:21 PM
ZACHTHOMAS20
Thanks for your reply! When you say "After that without a warning or CEL..." what are you referring to? Thanks again.
Apr 13, 2006 at 4:13 PM
BRUCE HUNT
  • 3,754 POSTS
Check engine light on the dash. The little picture of an engine that lights up when you turn on the ignition. If it stays on then you have some additional information from the computer to assist with the problem.
Apr 15, 2006 at 6:19 AM
Suggested Repair
Inspect the distributor cap and rotor, then verify ignition timing. If there is no check engine light, also consider a restricted catalytic converter.
Conversation Summary
A 1992 Honda Accord with about 140,000 miles sputters most at idle and loses power once fully warmed, bogging below about 3000 RPM. New spark plugs and wires did not help, and a fuel-system cleaning helped only slightly. The expert recommended checking the distributor cap and rotor, ignition timing, and possibly the catalytic converter if no check engine light is present, then explained what the check engine light is.
