1991 Honda Accord Door Locks Not Working
KIDD546
I just bought my daughter a 91' accord and the power door locks do not work. When the switch is moved the door lock controller clicks but nothing happens.
Jan 31, 2006 at 11:04 AM
2CARPRO JACK
  • 11,533 POSTS
might be the lock actuator, you need to pull the door panel and check for power and ground at the actuator, or remove the switch and test it there
Feb 2, 2006 at 6:46 AM
KIDD546
there is power at the switch and the realys in the control block click none of the actuators work.
Feb 2, 2006 at 9:03 AM
Suggested Repair
Pull the door panel and check for power and ground at the lock actuator, or test the switch circuit as advised. Power at the switch and clicking relays with no actuator movement point to the actuator or its power and ground circuit.
Conversation Summary
The owner of a 1991 Accord reported that the power door locks do not work; the door lock controller clicks when the switch is moved, but nothing happens. The expert said the lock actuator may be at fault and advised pulling the door panel to check power and ground at the actuator, or removing the switch and testing it there. The owner later reported power at the switch and clicking relays in the control block, but none of the actuators work.
