1997 Honda Accord P0141 O2 Heater Fix
MVLC1
My Tranny guy got a messge on his little read out:
PO141
O2 Heater Cucuit Malfunction
Bank 1 Sensor 2
1997 Honda Accord
4 Cyl w/AC
Can I replace this myself, and if so, will I be able to do it with my "Chilton" Manual?
Aug 3, 2007 at 6:00 AM
BRUCE HUNT
  • 3,754 POSTS
Yes you can replace it. Do some checking but I believe that is the aft catalytic converter o2. There are two on that vehicle.
Aug 6, 2007 at 4:09 AM
Suggested Repair
Replace the bank 1 sensor 2 oxygen sensor, which is likely the sensor aft of the catalytic converter. Confirm which of the two O2 sensors it is before replacement; a Chilton manual can guide the DIY job.
Conversation Summary
The owner of a 1997 Honda Accord 4-cylinder asked whether code P0141 (O2 heater circuit malfunction, bank 1 sensor 2) can be repaired at home with a Chilton manual. The expert said yes and identified it as likely the oxygen sensor aft of the catalytic converter, noting the vehicle has two O2 sensors.
