1992 Honda Accord No Fuel Pressure
BILLW
92 Honda Accord 4 cylinder no fuel pressure. Checked pressure regulator with clear vacuum line and looked ok, fuses inside are good, so I replaced the fuel pump. Car still doesen't run. Is there a relay or other check I can do ? no fuel pressure at the fuel rail and I cannot hear fuel pump kick on for 2 seconds when you turn the ignition like it is supposed to. Please help !!!
Oct 26, 2007 at 2:39 PM
MERLIN2021
  • 17,250 POSTS
either the IAC or the MAF
Aug 12, 2007 at 9:20 AM
  • 75,988 POSTS
You need to inspect and test your fuel injection main relay it powers the fuel pump thru the yellow wire at pin 4 at relay.
Oct 26, 2007 at 2:46 PM
BILLW
Can you give me an idea of where the relay is located and how it looks ? How many wires or some description to be sure I have the right one ? Thanks.
Oct 26, 2007 at 2:54 PM
  • 75,988 POSTS
Behind left side of dash see below
https://images.2carpros.com/forum/automotive_pictures/12900_relay_for_celica_94_1.jpg
Oct 26, 2007 at 9:31 PM
BILLW
Thank you ! The information was fast and helpful ! The diagram you showed me for a 94 accord makes it look like the relay is to the right of the steering wheel, and on a 92 model it's on the left kick panel above the fuse box. Once I found it and tested it, it was bad and replacing it did the trick ! Thank's again, B.W.
Oct 27, 2007 at 8:29 AM
  • 75,988 POSTS
You're most welcome and please! tell friends about us we're here to help people in need.
Once again TYVM for your donation and have a happy holidays from 2carpros.com
Oct 27, 2007 at 10:04 AM
Suggested Repair
Test and replace the fuel injection main relay, which powers the fuel pump. On a 1992 Accord it is on the left kick panel above the fuse box.
Conversation Summary
A 1992 Honda Accord had no fuel pressure and the fuel pump did not prime when the ignition was turned on. Interior fuses and the pressure regulator looked fine, and a new fuel pump did not fix it. An expert advised testing the fuel injection main relay, which powers the pump through the yellow wire at pin 4, and locating it behind the left side of the dash. The owner found the relay on the left kick panel above the fuse box, confirmed it was bad, and replacing it restored operation.
