1988 Honda Accord Raw Fuel in Oil
BTCONWOOD
I have a 1988 Honda Accord, 2.0 liter engine, approx 85k on this engine. Aquired car with a seized engine - got a used engine from a local junkyard - replaced several parts while engine was out, i.e clutch, pressure plate, release bearing, timing belt, drive belts, hoses, necessary gaskets. I used the intake, carb, and exhaust manifold from the seized engine because they were in better shape and the used engine did not have a carb. My first problem was a cracked stator magnet in the distributor causing very weak spark. Got car started, noticed fuel coming out aroung needle valve on top of carb - o-rings bad - also noticed fuel in oil. Rebuilt carb - still getting raw fuel in oil pan. Have been over and over vacuum hose routing, etc. Can't seem to find the cause - Please help!
Feb 18, 2007 at 9:15 PM
  • 75,988 POSTS
[quote:7998587b3f="btconwood"]I have a 1988 Honda Accord, 2.0 liter engine, approx 85k on this engine. Aquired car with a seized engine - got a used engine from a local junkyard - replaced several parts while engine was out, i.e clutch, pressure plate, release bearing, timing belt, drive belts, hoses, necessary gaskets. I used the intake, carb, and exhaust manifold from the seized engine because they were in better shape and the used engine did not have a carb. My first problem was a cracked stator magnet in the distributor causing very weak spark. Got car started, noticed fuel coming out aroung needle valve on top of carb - o-rings bad - also noticed fuel in oil. Rebuilt carb - still getting raw fuel in oil pan. Have been over and over vacuum hose routing, etc. Can't seem to find the cause - Please help![/quote:7998587b3f]
You sure its a Carb or it looks like it-if its a carb check the float adjustment. The only way for fuel to the crankcase is thru the Carb, also check the fuel pump pressure.
Feb 19, 2007 at 5:10 AM
BTCONWOOD
have checked that also - there is a sight glass on the side of the carb that enables you to observe the float level under various conditions - all in spec - have not checked fuel pump pressure, will do - i will let you know the outcome
Feb 19, 2007 at 1:53 PM
Suggested Repair
Confirm the carburetor float level is correct and test fuel pump pressure. Excess pressure or a flooding carburetor is the likely path for raw fuel into the crankcase.
Conversation Summary
A 1988 Honda Accord with a used 2.0L engine has raw fuel in the oil pan after a carburetor rebuild and vacuum-hose checks. The expert said fuel can reach the crankcase only through the carburetor and advised verifying the float adjustment and fuel pump pressure. The owner reported the sight-glass float level was in spec and planned to check pump pressure.
