1993 Honda Accord Losing Coolant
STA
My 93 honda accord was losing coolant my mechanic said it was my water pump he pressured tested it and thats what he saiid,he put a new pump on it but when I went back to check the coolant it was still losing coolant what could be my problem its not running hot and i don't see it leaking any where
Dec 4, 2006 at 1:20 AM
BRUCE HUNT
  • 3,754 POSTS
Is the car not running quite as well as it used to? Does it seem not to have the power that it had? I am guessing that you are burning water. This is probably a head gasket problem and if not it is a head crack or warpage.
Some auto repair shops will inspect the head for warpage and cracking. They can usually plane the head and do all of this for about $80. Cost of a head gasket is minimal and you are back in business. I know there is some work in getting the head off. It takes me about and hour and 1/2 to do so.
Jan 2, 2020 at 12:09 PM
GARFIELD
  • 197 POSTS
You may want to get your mechanic to do a compression test or a leak down test to pin point your probem with your car losing coolant. Are you seeing any white smoke while you are driving the car. If so Bruce is right that either you have a blown head gasket or a damage cylinder head.
Suggested Repair
Have a compression or leak-down test performed to check for coolant entering the cylinders. Inspect for white exhaust smoke and have the cylinder head checked for a failed head gasket, crack, or warpage; plane the head if needed and replace the head gasket.
Conversation Summary
A 1993 Honda Accord continued losing coolant after the water pump was replaced following a pressure test. It was not overheating and no external leak was visible. Experts suggested the coolant may be burning internally from a blown head gasket or a cracked or warped cylinder head, and recommended a compression or leak-down test plus checking for white smoke.
