Leaking 1992 Honda Accord LX
1992 HONDA ACCORD
SUPERSAIYANDOM
1. 1992 Honda Accord LX
2. 264561 kms
3. 5 speed transmission
4. 2 wheel drive
6. Engine Oil Leaks
Hey how's it going ?
I having a huge problem with my honda accord.
In a nut shell what's happening is that oil leaks or evening gushes out from the bottom of the engine when ever I turn on the engine. Just to note, I've not had any big repairs on it, just the usually maintenance.
I first saw this when I was driving home on day and saw a trail of oil coming into the driveway. When I saw that, I ended up seeing a huge puddle of oil from the bottom of my car. From the looks of it , it looks like all the oil from the engine gushed out. I checked the dip stick and it was empty.
I first tried putting in more oil, was fine while the engine is off, when I turned it on, that's when the oil starts gushing out. So pretty much I can't drive my accord right now.
I went under and made sure the oil plug > was tight
and also checked the oil filter > was tight
Couldn't really see where the oil was coming from. I guessin' or thinkin' it's either the oil pan or gasket.
I just curious what the problem maybe and what solutions I have. Also, wondering to what the cost might be (roughly) on the whole repair.
Thank you very much
Any suggestion would be very much appreciated
Jun 13, 2007 at 1:05 PM
BRUCE HUNT
  • 3,754 POSTS
I am going to bet this is a 4 cylinder. I'll tell you what you need to do. When you say "gush" that indicates a real leak and I don't really think it is a leak at the oil pan. I could be wrong.
Was the oil recently changed? Since there is probably not a lot of oil in the car I would pull the oil filter off and observe whether there are TWO gaskets on the filter. Check the filter and the car to see if you find an extra one.
Jun 14, 2007 at 1:00 AM
SUPERSAIYANDOM
Well, it happened probably I would say a week and a bit after a oil change, I usually do the oil changes myself, this one time I decided to go to lube world for some reason, I guess I just didn't have time to do it at the point hehe. But yeah the last oil change was at lube world which the incident happened a week and a bit after that oil change.
But I will check the Oil Filter as well.
Thanks for your suggestion very much appreciated
Talk to you again
Jun 14, 2007 at 5:37 AM
DESERTSHADOW
  • 5 POSTS
This started happening after the OIL CHANGE, didn't it? I'll bet you a million that I know what is causing this, because I just solved an identical problem. I changed my oil, identical symptoms. I kept tightening the filter, then swapped out for a new.
THEN, the old filter O-ring came tumbling off. The ORIGINAL filter's o-ring had stuck to the mounting flange. so it was stacking two o-rings on the flange!!!! I have neither ever had this happen or even heard of it happening! I replaced with new filter, insuring that flange was clear and clean, and NO LEAK! Maybe this is a problem inherent to Honda's.
Moral: when you remove an oil filter -or at a shop- insure that the old o-ring comes off with the filter!
Good Luck
Jul 1, 2007 at 8:39 AM
