High RPM, Honda Accord 1988, 100K
MELROYZ
My honda Accord has a relatively high RPM when being driven, 3000+ at 50MPH (the idling RPM is set to 1000). This causes the engine to overheat on long drives. This happened after a quack auto mechanic adjusted my carburetor.
Any advises how to get this rectified?
Nov 3, 2006 at 7:04 PM
BRUCE HUNT
  • 3,754 POSTS
The high rpm is totally dependant upon the amount of pedal you put to the engine. If the engine rpms are that high are you sure the tranny is shifted into overdrive? The low end idle of 1000 is high. I would have it set lower to around 750.
The overheating although associated with the engine is probably being causes by something else such as low coolant, bad thermostat, plugged system, bad radiator cap, etc.
Check the tranny for the shifting, you havent said if it is auto or manual.
Nov 4, 2006 at 12:05 AM
MELROYZ
Hi Bruce. Thank you for the quick response.
My honda is auto transmission. I will surely have the tranny checked out.
As far as setting the idling RPM to 750, I have tried that and the engine shuts off when I have to stop the car with the gear engaged in drive (at stop signs). Please advise.
Nov 4, 2006 at 7:28 PM
BRUCE HUNT
  • 3,754 POSTS
How are you raising the idle speed? At 750 she should purr. Take some time to pull off the Idle Air Control Valve and clean it. Take it apart and clean the screens. Clean it very well and see if the makes a difference.
Nov 5, 2006 at 1:20 PM
MELROYZ
A few taps on the Idle Air Control Valve with a screw driver really improved the idling rpm. As suggested by you I think this could have been the most likely cause for the falling rpm/stalling engine. By the way, how do you check the tranny for overdrive?
Nov 10, 2006 at 7:02 PM
BRUCE HUNT
  • 3,754 POSTS
Well I suspect your car has a position on the shifter of D3 and D4. If you run it in the D3 position to about 50 mph and then shift to D4 it should shift the tranny and you should see the rpm go down. The car should now be in overdrive.
Nov 10, 2006 at 7:33 PM
MELROYZ
Thanks Bruce. I will try this and get back to you.
Nov 11, 2006 at 7:19 PM
