i parked my car and went on vocation every thing was fine until then after 20 days when i came back and started my car it was running ok on idle. but as soon as i accelerated RPM started fluctuating. when i kept pressed accelerator car does't accelerated . when i pressed accelerator hard it moves with jurk and then after some time even i kept accelerator pressed RPM started coming down. i drived for 20Km it kept on doing same. i brought it to mech he replaced fuel pump, nothing changed, then he changed fuel regulator no change. when he manually turn fuel regulator off, car acceleration becomes ok. the moment he turn regulator on again every thing was same again. he had also cleaned fuel injectors.engine scan did not revieled any code. i have given ECU reset by disengageing battery connector for half an hour and then connecting it back after five minutes when i started it every thing was ok. after driving almost 20 to 25 Km now again it has started same RPM fluctuations.
Jun 30, 2008 at 12:28 PM
