HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Accord
Engine
Symptoms
Revs Up
SPONSORED LINKS
1988 Honda Accord Engine idling
MAXWHAT
MEMBER
1988 HONDA ACCORD
4 CYL
2WD
AUTOMATIC
219,000 MILES
The engine races, the RPM's are erratic. The tach will go up and down.
Tuesday, March 31st, 2009 AT 3:02 AM
KHLOW2008
MECHANIC
Hi maxwhat,
Is this a carburetted or injection model?
SPONSORED LINKS
Tuesday, March 31st, 2009 AT 1:35 PM
MAXWHAT
MEMBER
It is fuel injected.
Tuesday, March 31st, 2009 AT 4:36 PM
KHLOW2008
MECHANIC
The erratic rpm is commonly termed as "surging" and mostly due to a fault in the idling system, adjustment or vacumn leakages.
1. Check for disconnected vacumn hoses. Faulty PCV would allow uncontrolled amount of air into cylinders.
2. Check radiator coolant level.
3. Check for clogged cooling hoses to fast idle valve.
4. Check idle adjust screw.
Wednesday, April 1st, 2009 AT 8:28 AM
Please
login
or
register
to post a reply.
Related Engine Revs Up Content
High Rpm, Honda Accord 1988, 100k
My Honda Accord Has A Relatively High Rpm When Being Driven, 3000+ At 50mph (the Idling Rpm Is Set To 1000). This Causes The Engine To...
Asked by
melroyz
1988
HONDA ACCORD
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
88 Accord Lxi 5 Spd Rpm Gague Erratic
Hi - I Have An 88 Accord Lxi Hatch 306k Miles. After At Least 16 Trouble Free Months, The Rpm Gague Started To Bounce Around Every Few...
Asked by
88Accord
1 ANSWER
1988
HONDA ACCORD
2000 Honda Accord Engine Rpm Fluctuation
I Parked My Car And Went On Vocation Every Thing Was Fine Until Then After 20 Days When I Came Back And Started My Car It Was Running Ok On...
Asked by
iamfurqan
2000
HONDA ACCORD
Rpm Jerking
I Just Got A Used Honda Accord And The Rpm Just Drops When Take My Foot Of The Gas And Goes Down Close To 1, No Effect On The Cars Drive....
Asked by
mshadym
2000
HONDA ACCORD
95 Honda Accord Revving Up/dn
I Own A '95 Honda Accord 4cyl With 123,000 Miles And Last Month Got A New Timing Belt & Water Pump From A Reputable Shop. Since Then, And...
Asked by
HondaGuy100
1999
HONDA ACCORD
VIEW MORE
SPONSORED LINKS
Vacuum Leak Symptoms
Vacuum Leak
Online car repair manuals
