Headache 1993 ACCORD
TWOLFE2409
1993 Accord EX Automatic 107000 miles. While driving, my car sometimes hesitates and then just shuts off. the radio and lights stay on. every time it has happened, i was on the freeway. i pull over to the side and i have to cut the car all the way off and it starts right up. if i just turn the key forward it wont start. i have turn the key all the way back and then turn it forward. sometimes i can drive the car all day and it MAY OR MAY NOT happen. but when it does, it will continue to cut off. i have replaced the ignitor, fuel pump, relay switch, splugs and wires. HELP, I LUV MY HONDA.
Nov 7, 2006 at 2:12 PM
BRUCE HUNT
  • 3,754 POSTS
This sounds like the Electron Fuel Injector relay located up under the dash on the driver side.
Nov 8, 2006 at 2:12 AM
TWOLFE2409
Is that the main relay? That was replaced already.
Nov 8, 2006 at 6:33 AM
BRUCE HUNT
  • 3,754 POSTS
Does the CEL come on? When you turn the key on and all the dash lights come on does the CEL light work? Check all of the connection from the battery to the starter and check the grounds. This is electrical and could point to little things like the switch itself.
Nov 9, 2006 at 6:03 PM
