1994 Honda Accord Fuel Pump
CSH13500
  • 1994 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 235,000 MILES
Ono fuel to the rail: fuses are good, but the pump does not turn on when the key is in the "on" position. I have tested the main relay, and even replaced it. I can jump the pump out to 15V and it runs, but when the key is "on" or in "strat" no pump action. What do I do?
Saturday, July 4th, 2009 AT 10:19 AM
KHLOW2008
  • 41,814 POSTS
Hi csh13500,
When ignition switch is turned ON, the pump would only receive power for 2 seconds.
Did you test the PGM-FI main relay power supply to fuel pump?
Does the Check Engine Light shows for 2 seconds and goes off when ignition switch is turned ON?
Saturday, July 11th, 2009 AT 1:22 PM
