1995 Honda Accord No Power After Crash
SURFMUSIC89
1995 Honda Accord Ex 100,000 4 cylinder
i recently got in a accident and smashed up my drivers side front end, the airbags did deploy on the driver and passenger side, the car now wont start. everything seems to be ok with the engine and mechanics of it, just body damage, and the airbags. Does the car not start because the airbags deployed?
And if so how can i get it to start again so i can just drive it to the auto shop down the street, i don't want to have to pay for a tow.
when i say the car wont start i mean that when you put the key in the ignition and try to turn the key, you cant even turn the key the ignition is locked or something
by turning the wheel the key now turns but nothing happens. I turned the key and nothing, not the radio, the alarm, the lights, nothing will turn on. What could it be?
And does the 1995 honda accord ex have a saftey feature which makes the car not work after the airbags deploy
Jul 9, 2007 at 7:03 AM
BRUCE HUNT
  • 3,754 POSTS
Maybe you could describe what the not starting entails. For instance, does it turn over but not engage or is there nothing when the key is turned?
Jul 9, 2007 at 8:23 AM
SURFMUSIC89
[quote:443db0aee8="Bruce Hunt"]Maybe you could describe what the not starting entails. For instance, does it turn over but not engage or is there nothing when the key is turned?[/quote:443db0aee8]
actually the ignition is locked or something, you can't even turn the key, nothing will turn on
Jul 9, 2007 at 8:46 AM
BRUCE HUNT
  • 3,754 POSTS
Sometimes when you have pressure on the wheel as it locks from turning this stops the key from turning. Try turning the wheel and moving the key.
Jul 11, 2007 at 2:54 AM
SURFMUSIC89
Jul 11, 2007 at 4:43 AM
BRUCE HUNT
  • 3,754 POSTS
I do not believe so but have you checked the main fuse under the hood? Should be about an 80 to 100 amp fuse?
Jul 11, 2007 at 8:29 AM
Suggested Repair
After freeing the steering lock by turning the wheel, check the main under-hood fuse, typically about 80 to 100 amps. The expert does not believe airbag deployment itself disables the car.
Conversation Summary
A 1995 Honda Accord EX with front-end collision damage and deployed airbags would not start. The ignition was locked until the steering wheel was turned; the key then turned, but nothing powered on, including the radio, alarm, and lights. The owner asked whether airbag deployment disables the car. The expert said that is not believed to be the case and recommended checking the main fuse under the hood, about 80 to 100 amps.
