1997 Honda Accord
97,000 MILES • 4 CYL • FWD • AUTOMATIC
FORDCRETER
how do I remove the rotor from the front end? I have removed the axle bolt and the brake caliper!
Sep 4, 2010 at 7:59 AM
KHLOW2008
  • 41,812 POSTS
Hi fordcreter,
You need to disconnect the lower ball joint and take out the CV joint and from behind remove the 4 bolts holding the bearing.
Rotor has to come out together with the wheel bearing.
Sep 6, 2010 at 6:23 AM
