1998 Honda Accord Floor Vents Don't Work
JACCORD
Have a 1998 Honda accord with 35,000 miles automatic transmission. I have automatic climate control and when the heat goes on the air continues to blow out of the front two vents and will not flow to the floor. I tried to manually overrdie to floor and/or to windsheild(defrost) but it continues to blow thru front vents only. The cooling works correctly. Any hints to what the problem is.
Thanks
Sep 12, 2007 at 1:34 PM
BRUCE HUNT
  • 3,754 POSTS
Damper door not operating, I would check a fuse first. I am sending you more material than you possibly will need but one item in there is a diagnostic test. Follow the directions and try that. There is an exit procedure for the diagnostics, make sure you do that too.
Sep 13, 2007 at 1:32 AM
Suggested Repair
Check the climate-control fuse first, then diagnose the mode damper door that directs airflow. Run the climate-control diagnostic and complete its exit procedure.
Conversation Summary
A 1998 Honda Accord with automatic climate control continues blowing air from the front dash vents when heat, floor, or defrost is selected, although cooling works. The expert says the mode damper door is not operating and recommends checking a fuse first, then following the climate-control diagnostic procedure and its exit steps.
