1991 Honda Accord Backfire
SHAZ
1991 Honda Accord LX mileage: 98,900. My car started backfiring on me when i was driving it. It would only backfire when I started to drive, but when I rev the engine when I'm not moving the car does not backfire. When I got back to my house I looked under the car and noticed that the catalytic converter was red. The car has new spark plug wires. Also took out the spark plug from the first cylinder and noticed that it looked like it was burned/charred. Thanks for the help.
May 8, 2007 at 1:39 PM
BRUCE HUNT
  • 3,754 POSTS
Have you checked the timing of the car? Have you noticed a lack of power to the vehicle as well and a loss of economy?
May 9, 2007 at 2:45 AM
SHAZ
Thank you for your reply. Yes, the car is very weak on take off. It was near 4k rpm and was still extremely weak. Also the engine shakes a little.
May 9, 2007 at 7:03 AM
BRUCE HUNT
  • 3,754 POSTS
I doubt that the black on the plug is oily but it is likely sooty which indicates that the engine is running rich. You could check the timing, but first check the PCV and the EGR valve. The EGR can be cleaned.
May 9, 2007 at 9:23 AM
PCHOMINSKI
  • 17 POSTS
Stuck or pluged EGR will not cause rich mixture.
I would suspect timing - not only ignition, but cam shaft versus crank shaft. Maybe timing belt jumped.
May 10, 2007 at 1:58 PM
Suggested Repair
Check ignition timing and camshaft-to-crankshaft timing for a jumped timing belt. Also inspect the PCV valve and clean the EGR valve; a sooty plug suggests a rich mixture that can overheat the catalytic converter.
Conversation Summary
A 1991 Honda Accord backfires while driving but not when revved in place, feels very weak on takeoff, shakes slightly, and had a glowing catalytic converter. New plug wires are installed, and the first-cylinder plug looked burned or charred. One expert suspected a rich mixture and advised checking timing, the PCV valve, and cleaning the EGR. Another said a stuck EGR would not cause richness and suspected ignition or cam-to-crank timing, possibly a jumped timing belt.
