1989 Honda Accord Cylinder Leak
CRAFTECH
89 Accord - 250,000 Miles. Carburetor model. LX Automatic
Had a problem with smoke and oil entering air cleaner. Decided to replace valve stem seals. Removed all spark plugs, rocker arm assembly, distributor, tiing belt, cam, etc.
Discovered that the number 2 cylinder would not pressurize when using the KD air hold hose.
Compressed Air is coming up from the oil drain hole in the cylinder head in the corner next to the number 1 cylinder (timing belt side).
Before I go any further, can you think of anything short of blown rings or a cracked casting that can cause this?
I have a few broken exhaust manifold studs, but I don't see how that could cause this problem.
And it would seem to me that the head gasket wouldn't cause this either.
Any suggestions? Thanks.
May 18, 2006 at 12:19 AM
LOSONE
  • 1,616 POSTS
You have classic "blow by" which is caused by a tired engine especaily the rings and deposits oil in the breather.
Remember Honda cylinders are not all the same size so rebuilding is a night mare unless you bore each hole. They are colored coded and with all the miles the color is gone. Good luck
May 18, 2006 at 10:48 AM
Suggested Repair
Treat the failed cylinder pressure and air escaping through the head oil drain as classic ring blow-by from a worn high-mileage engine. A rebuild is difficult because Honda cylinders are color-coded and not all the same size, so each bore must be measured and bored individually.
Conversation Summary
The owner of a 1989 Honda Accord with 250,000 miles found oil and smoke entering the air cleaner while replacing valve stem seals. Cylinder 2 would not hold air, and compressed air escaped through the oil drain hole in the cylinder head. The expert identified classic blow-by from worn rings and noted that rebuilding is complicated because the color-coded cylinders are not all the same size and must be bored individually.
