1991 Honda Accord CV Axle Falls Out
CHRIS81
I drive a 91 honda accord ex. The problem is that I replaced the passanger cx axle, and After about 40 miles the axle comes out of the transmission. I have to jack the car up and take the tire off, push the axle back in, but the process repeats itself. How do I correct that from falling out? Please help. :?
Oct 15, 2007 at 9:49 AM
FISHERMAN
  • 937 POSTS
[quote:779c203718="chris81"]I drive a 91 honda accord ex. The problem is that I replaced the passanger cx axle, and After about 40 miles the axle comes out of the transmission. I have to jack the car up and take the tire off, push the axle back in, but the process repeats itself. How do I correct that from falling out? Please help. :?[/quote:779c203718]
Hello !!
well looks like the "C" ring its to tight on to the shaft or its missing..
check it out and let us know!
Oct 15, 2007 at 9:53 AM
Suggested Repair
Inspect the passenger axle retaining C-clip. It may be missing or too tight on the shaft, so it does not lock the axle into the transmission. Install or replace the C-clip correctly so the axle stays seated.
Conversation Summary
The owner of a 1991 Honda Accord EX replaced the passenger CV axle, but after about 40 miles it pulls out of the transmission and has to be pushed back in. The expert says the C-ring is either too tight on the shaft or missing and should be checked.
