1998 Honda Accord HOW TO CHANGE THE CV JOINT ON A 1998 HON
SWAN88882003
  • 1998 HONDA ACCORD
Suspension problem
1998 Honda Accord 4 cyl Two Wheel Drive Automatic 172K miles
I NEED TO KNOW HOW TO CHANGE OUT THE DRIVER SIDE CV JOINT.
Tuesday, October 21st, 2008 AT 2:32 PM
KHLOW2008
  • 41,814 POSTS
Hi swan88882003,
You need to
1. Remove wheel.
2. Remove CV shaft locknut.
3. Disconnect the lower arm ball joint.
4. Pull the our joint out of the hub.
5. Pry the CV shaft from the transmission.
6. Reinstall new shaft.
Monday, October 27th, 2008 AT 4:28 AM
