1997 Honda Accord Windows Mirrors Blinkers
JULIET
1997 HONDA ACCORD EX 4DR DRIVER SIDE WINDOW WOULDNT GO DOWN CHANGED THE WINDOW REGULATOR AND IT GOES DOWN NOW BUT THE FRONT PASSENGER DOES NOT AND ALSO MY MIRROWS WONT WORK ALSO MY BLINKERS WONT BLINK EIGHTER IS THIS AN ELECTRICAL PROBLEM??? TRYING NOT TO SPEND A LOT OF MONEY
Mar 20, 2007 at 8:13 AM
BRUCE HUNT
  • 3,754 POSTS
I would say this is electrical but have you checked fuses and good and I mean good grounding?
Mar 20, 2007 at 9:33 AM
JULIET
YES I HAVE CHECKED THE FUSES AND THEY ARE GOOD COULD IT BE A SHORT???
Mar 20, 2007 at 9:40 AM
MIKE H R
  • 3,094 POSTS
what I picked up that the windowns are manual? for the blinkers do they stay on the front and back when you turn your signal on? if they do it could be from a bad ground or corroded socket. the flasher might be bad. if the windows are manual you could spray some lubricant onto the regulatorand try to free the window .
Mar 20, 2007 at 10:37 AM
JULIET
1997 HONDA ACCORD EX 4DR WINDOWS ARE NOT MANUAL EVERYTHING IS ELECTRICAL THEY DONT STAY ON BACK OR FRONT. SOMETIMES THEY WORK AND SOMETIMES THEY DONT.
Mar 20, 2007 at 12:22 PM
MIKE H R
  • 3,094 POSTS
about your signal lights, i would check the bulbs and the connections on each signal light, there could be rust or something from getting a good connection.if they are ok then it would be the flasher. don't think its the flasher with them working sometimes.
Mar 20, 2007 at 12:50 PM
Suggested Repair
Fuses were already checked and found good. Thoroughly inspect grounds, then check the signal bulbs, sockets, and connections for corrosion or poor contact. Because the blinkers work only sometimes, the flasher is less likely. The passenger window and mirrors may share the same electrical or ground problem.
Conversation Summary
The owner of a 1997 Honda Accord EX said the driver window was fixed by replacing the regulator, but the passenger window, mirrors, and turn signals still fail. The signals work only intermittently and do not stay on. Experts said the problem is electrical and recommended verifying fuses, checking for a good ground, and inspecting signal bulbs and connections for corrosion; a flasher was considered less likely.
