1990 Honda Accord Won't Shift
VICKSHONDA
1990 honda accord ex with 90k
when I start the car I cannot shift into drive unless
I stick a key into the slot next to the stick.Once I do
this Im ok.Whats wrong??????
Oct 11, 2006 at 6:15 PM
BRUCE HUNT
  • 3,754 POSTS
Getting a check engine light as well? Some associate the problem to faulty battery, power to the sensor on the tranny, but I believe it is electrical in nature, your problem is.
Oct 12, 2006 at 4:24 AM
VICKSHONDA
[quote:70c73c5da2="vickshonda"]1990 honda accord ex with 90k
this Im ok.Whats wrong??????[/quote:70c73c5da2]
Oct 12, 2006 at 5:56 AM
BRUCE HUNT
  • 3,754 POSTS
Usually when the key is required to shift the tranny that is caused when a sensor on the brake is bad or not aligned to work with the pedal.
Oct 23, 2006 at 8:52 AM
Suggested Repair
Inspect the brake pedal position switch that controls the shift interlock. Realign it with the pedal or replace it if it is faulty so the shifter releases without using the key override.
Conversation Summary
A 1990 Honda Accord EX owner cannot shift into drive after starting unless a key is inserted in the slot beside the shifter. The expert first considered an electrical issue such as battery power to a transmission sensor, then said the key override is usually needed when the brake pedal sensor is bad or misaligned.
