1999 Honda Accord Burning Oil
Suggested Repair
Have a compression test, vacuum test, and spark plug analysis performed to determine why the engine is burning oil. If the rings are worn, the engine must be removed and rebuilt; if the valves are the cause, the cylinder head or heads must be removed and rebuilt or replaced. Cost depends on which fault is found.
Conversation Summary
The owner of a 1999 Honda Accord EX with 143,000 miles reports burning about 2 quarts of oil every 2,500 miles. The check engine light comes on when the oil level drops and goes off after oil is added. The expert says the cause must be diagnosed before estimating cost and recommends compression, vacuum, and spark plug tests. Worn rings would require an engine rebuild, while valve problems would require head work; either repair is expensive.
