BLEEDING MY CLUTCH
VISIONZTECHNOLOGY
1992 HONDA ACCORD 2.2 LX 500K , AFTER FILLING WITH BRAKE FLUID , TRIED TO DEPREES CLUTCH , WENT TO THE FLOOR. IT WOULD NOT ENGAGE. THE FLUID NEVER WENT DOWN EITHER FOR BLEEDING. DO YOU KNOW WHAT I AM DOING WRONG?
Jul 30, 2007 at 8:18 AM
BRUCE HUNT
  • 3,754 POSTS
Either the seals are that bad in the master or you have a possible opening that is not allowing the system to accept pressure. Is the bleeder open? You may have to pull the pedal off the floor. Pump it several times to see if it has any resistance.
Jul 30, 2007 at 8:50 AM
