1995 Honda Accord Rich Idle and Stalls
Got OBD2 code/s -your running rich-could be a leaky injectors or punctured fuel pressure regulator. I still got more coming.
Got OBD2 code/s -your running rich-could be a leaky injectors or punctured fuel pressure regulator. I still got more coming.[/quote:589dbf218b]
no codes black smoke is only at idle leans out when reved?
Got OBD2 code/s -your running rich-could be a leaky injectors or punctured fuel pressure regulator. I still got more coming.[/quote:4e6530d8b7]
no codes black smoke is only at idle leans out when reved?[/quote:4e6530d8b7]
Run a high tech fuel injector/s cleaner to it and see what happens
Okay check the coolant temperature sensor and the oxygen sensor/s and tell me what they doing is it switching accordingly to open and closed loop mode.
You need a scan tool to do above.
Got OBD2 code/s -your running rich-could be a leaky injectors or punctured fuel pressure regulator. I still got more coming.[/quote:43408120a2]
no codes black smoke is only at idle leans out when reved?[/quote:43408120a2]
You need a scan tool to do above.[/quote:43408120a2]
checked O2 and cts according to haynes manual w/ volt meter seems ok was wrong about rpm's can't get it over 3000 and thats if you push really slow if you stab it, it stalls. OBD2 code 41 w flashing check engine light haynes calls it o2 sensor heater after reseting ECM no codes. exhaust was full of water from blown head gasket!
Got OBD2 code/s -your running rich-could be a leaky injectors or punctured fuel pressure regulator. I still got more coming.[/quote:7276a9a135]
no codes black smoke is only at idle leans out when reved?[/quote:7276a9a135]
You need a scan tool to do above.[/quote:7276a9a135]
checked O2 and cts according to haynes manual w/ volt meter seems ok was wrong about rpm's can't get it over 3000 and thats if you push really slow if you stab it, it stalls. OBD2 code 41 w flashing check engine light haynes calls it o2 sensor heater after reseting ECM no codes. exhaust was full of water from blown head gasket![/quote:7276a9a135]
Disconnect the exhaust pipe at the exhaust manifold retest( wear ear muffs ) sounds like clogged-up converter. Also you might want to change the HO2 sensor.
Got OBD2 code/s -your running rich-could be a leaky injectors or punctured fuel pressure regulator. I still got more coming.[/quote:ffe0d9ab67]
no codes black smoke is only at idle leans out when reved?[/quote:ffe0d9ab67]
You need a scan tool to do above.[/quote:ffe0d9ab67]
checked O2 and cts according to haynes manual w/ volt meter seems ok was wrong about rpm's can't get it over 3000 and thats if you push really slow if you stab it, it stalls. OBD2 code 41 w flashing check engine light haynes calls it o2 sensor heater after reseting ECM no codes. exhaust was full of water from blown head gasket![/quote:ffe0d9ab67]
Disconnect the exhaust pipe at the exhaust manifold retest( wear ear muffs ) sounds like clogged-up converter. Also you might want to change the HO2 sensor.[/quote:ffe0d9ab67]
disconnected exhaust in front of cat. wouldn't even start. discoverd timing was off by a tooth on cam, re-timed it it's a little better but basically still doing the same thing you can now get it to 4000rpm's if you feather it, but now if you hold throttle still at say 2000 rpm's after about 5 seconds it starts to surge between 900rpm's and 2000 rpm's with your foot still
and there are still no codes still runs rich at idle and dies when you press throttle. the most annoying thing is the car ran great before blown head gasket
Got OBD2 code/s -your running rich-could be a leaky injectors or punctured fuel pressure regulator. I still got more coming.[/quote:80b58c97a7]
no codes black smoke is only at idle leans out when reved?[/quote:80b58c97a7]
You need a scan tool to do above.[/quote:80b58c97a7]
checked O2 and cts according to haynes manual w/ volt meter seems ok was wrong about rpm's can't get it over 3000 and thats if you push really slow if you stab it, it stalls. OBD2 code 41 w flashing check engine light haynes calls it o2 sensor heater after reseting ECM no codes. exhaust was full of water from blown head gasket![/quote:80b58c97a7]
Disconnect the exhaust pipe at the exhaust manifold retest( wear ear muffs ) sounds like clogged-up converter. Also you might want to change the HO2 sensor.[/quote:80b58c97a7]
[/quote:80b58c97a7] one more thing the 2 prong distributor drive gear that goes into the cam shaft is missing one side
Got OBD2 code/s -your running rich-could be a leaky injectors or punctured fuel pressure regulator. I still got more coming.[/quote:3c3afee02b]
no codes black smoke is only at idle leans out when reved?[/quote:3c3afee02b]
You need a scan tool to do above.[/quote:3c3afee02b]
checked O2 and cts according to haynes manual w/ volt meter seems ok was wrong about rpm's can't get it over 3000 and thats if you push really slow if you stab it, it stalls. OBD2 code 41 w flashing check engine light haynes calls it o2 sensor heater after reseting ECM no codes. exhaust was full of water from blown head gasket![/quote:3c3afee02b]
Disconnect the exhaust pipe at the exhaust manifold retest( wear ear muffs ) sounds like clogged-up converter. Also you might want to change the HO2 sensor.[/quote:3c3afee02b]
[/quote:3c3afee02b] one more thing the 2 prong distributor drive gear that goes into the cam shaft is missing one side[/quote:3c3afee02b]
Could be the culprit-now you need another distributor
Got OBD2 code/s -your running rich-could be a leaky injectors or punctured fuel pressure regulator. I still got more coming.[/quote:5af72897f8]
no codes black smoke is only at idle leans out when reved?[/quote:5af72897f8]
You need a scan tool to do above.[/quote:5af72897f8]
checked O2 and cts according to haynes manual w/ volt meter seems ok was wrong about rpm's can't get it over 3000 and thats if you push really slow if you stab it, it stalls. OBD2 code 41 w flashing check engine light haynes calls it o2 sensor heater after reseting ECM no codes. exhaust was full of water from blown head gasket![/quote:5af72897f8]
Disconnect the exhaust pipe at the exhaust manifold retest( wear ear muffs ) sounds like clogged-up converter. Also you might want to change the HO2 sensor.[/quote:5af72897f8]
[/quote:5af72897f8] one more thing the 2 prong distributor drive gear that goes into the cam shaft is missing one side[/quote:5af72897f8]
Could be the culprit-now you need another distributor[/quote:5af72897f8]
could i just replace the gear/cog?
Suggested Repair
Replace the distributor, or replace the broken camshaft distributor drive gear if it can be serviced separately. Confirm cam timing is correct. If the rich idle and stalling continue, also check for a clogged catalytic converter and a faulty heated oxygen sensor.
Conversation Summary
A 1995 Honda Accord automatic 2.2 VTEC with 164,000 miles ran poorly after a head gasket and timing belt job, with black smoke at idle, a rich condition, surging, and stalling or limited rpm under throttle. No codes remained after an ECM reset, though code 41 for the oxygen sensor heater had appeared. The owner found the cam timing one tooth off and corrected it with only slight improvement, and reported that one side of the two-prong distributor drive gear was missing. The expert identified that damaged drive as a likely cause and advised replacing the distributor, or the gear if it can be replaced separately.
