1984 Honda Accord Idle Stalling
JIMYONALLY
OK first off the car has and had several problems that I'm slowly working on. Bought the car Feb 2006 didn't want to run much past 5 miles from home in the mornings. Would stall when coming to a stop, low power and jerky when driving, sometimes would clear up sometimes wouldn't in the next 10 miles. Always cleared up in the afternoon. I messed around with the engine off and on until it ran fine (HINDSIGHT, MORNINGS GOT WARMER). Drove all summer long with rare problems. Blew and had replaced head gasket after which the car was running rough. Front float on carb needed to be adjusted (some fuel leakage around screw). Last two mornings the car is back to it's old tricks (MORNINGS ARE NOW COLDER). Runs OK for about five miles, dies unless I hold my foot on the accelerator when stopping, very low power while driving, clears up 2-3 miles later.
The car has new rotor/cap/wires/plugs/timing belt.
I probably need a rebuilt carb or a rebuild kit (leaky screw).
Possible culprits are timing advance, fuel supply or ???
Any recommendations?
Car is:
Honda Accord, 1984, 5 speed
218,000 miles
Carburetor Keihin
has 3-4 casted in the body
has ??90C 105020 on a tag
Oct 24, 2006 at 5:10 PM
BRUCE HUNT
  • 3,754 POSTS
The loss of power got me thinking about the problem you had with the head gasket. When you had the head gasket problem and probably way before that did the car ever get real hot. I suspect that it did and probably sometime previously with the old owner. Here is my thought that I would start with. Pull the head off again and take it to a parts store with a shop. They will test it with a spray to find out if the head is cracked and they will find out if the head is warped. It can be plained to fix the problem. IF you had this done when the head gasket blew forget it. I suspect that over time you are loosing a small amount of coolant and this though unnoticable is being secretly burned in the cylinders and causing the bad running of the engine and loss of power. If not let me know.
Oct 25, 2006 at 12:26 AM
JIMYONALLY
When the head gasket was replaced the head was plained when the gasket was replaced but, I don't know if it was checked for cracks. Yes at least once about when the head gasket began to go I'm not sure how far I drove with the problem about 15 miles home from work at about 10 miles I noticed the engine sounding odd, no loud noises, and that's when the temp guage was maxed out. I couldn't stop right away because of traffic but, as I slowed down the temp guage came down. It stayed on the high side. I drove completely home and I noticed over the next few days if I took it easy the temp guage stayed about 3/4, normal is just above 1/2. If I drove a little harder the temp would climb and if I took it easy the temp would drop off. Now temp is staying pretty normal. And today, cold morning, it ran fine!
Oct 25, 2006 at 8:00 PM
Suggested Repair
Have the cylinder head inspected for cracks. It was planed when the head gasket was replaced, but prior overheating may have cracked it, allowing small coolant loss into the cylinders and causing cold-morning stalling and power loss.
Conversation Summary
A 1984 Honda Accord with a Keihin carburetor stalls when stopping and loses power for the first several miles on cold mornings, then clears up. New ignition parts and a timing belt are already installed, and the head was planed during a recent head-gasket repair after the engine overheated. The expert suspects a cracked head is letting a small amount of coolant burn in the cylinders and recommends crack testing. The owner reports the temperature is now normal and the car ran fine on a later cold morning.
