1982 Honda Accord Poor Acceleration
BOARDERBW
  • 19 POSTS
1982 Honda Accord, mileage: 200,000
My car is having problems accelerating. It is a manual transmission. When my car was working properly i would press the pedal half way and it would easily get up to speed. Now I have to floor it and it barely gets up to speed. Also it has a slight problem keeping idle. It also stalls easier. What is wrong with my car?
Sep 22, 2006 at 8:28 AM
BRUCE HUNT
  • 3,754 POSTS
Are you losing any coolant from the system? Have you had a compression check done? I am thinking head or head gasket.
Sep 26, 2006 at 12:03 AM
BOARDERBW
  • 19 POSTS
No. Its not running hot at all. No I havent had compression check. After using my car a little more I realized that it is idling ok and it doesn't stall but it is having trouble accelerating and getting up to speed. The other day I was going into town on the highway and i floored it for about a mile and my top speed was 65. It was shaking abnormally too. I don't know if that has anything to do with my acceleeration problem or not. Do you think it could be the fuel pump?
Sep 26, 2006 at 2:56 PM
BRUCE HUNT
  • 3,754 POSTS
Check the plugs to see if they are fouling. I would suspect that you fuel efficiency has been poor. Have you checked the timing? If the plugs seem wet and or black sooty you are getting plenty of fuel but not getting the spark properly timed or even the possibility of not a good spark being present. So check the plugs. Wires on the plugs are very critical.
Sep 27, 2006 at 6:11 AM
Suggested Repair
Inspect the spark plugs for wet or black sooty fouling, then check ignition timing and the plug wires. Poor acceleration with adequate fuel can indicate weak or mistimed spark rather than a fuel-pump problem.
Conversation Summary
A 1982 Honda Accord with a manual transmission has poor acceleration, previously had idle and stalling concerns, and shook while reaching only about 65 mph when floored. The owner reported no overheating and asked about the fuel pump. The expert first raised a possible head or head-gasket issue and suggested a compression check, then advised inspecting the plugs for fouling and checking ignition timing and plug wires.
