1992 Honda Accord Sun No-Start
EMLJACK
my 92 accord lx, 2.2 l auto trans. 4 door will not start if left in bright sun for more than an hour or two. No signs of overheating, smells etc. car turns over quickly etc. but wont kick in.Have good spark at all plugs. tried loosening gas cap incase of vac lock. Im lost on this one. Thanx!
Jul 9, 2007 at 3:02 PM
EMLJACK
gimme a couple days, right now I got 8 bucks, if (20,s) o.k. Gimme a couple days, waitin on the customer from vaca. Thanx for your service prolly saves millions nationwide!
Jul 10, 2007 at 5:18 PM
BRUCE HUNT
  • 3,754 POSTS
Do your self a favor and look up under the dash on the driver side. There is a lot of stuff under there but there is a box that controls the fuel. The EFI relay will likely fix your problem. Sometimes you can resolder the connections but usually it is a replacement item.
Jul 11, 2007 at 3:32 AM
Suggested Repair
Inspect the EFI fuel-control relay in the box under the driver-side dash. Resoldering the connections sometimes helps, but the relay usually needs to be replaced.
Conversation Summary
A 1992 Honda Accord LX cranks and has spark but will not start after sitting in bright sun for an hour or two, with no overheating signs. Loosening the gas cap did not help. The expert advised checking the EFI relay under the driver-side dash and replacing it, noting that resoldering the connections is only sometimes effective.
