I have a 2005 Honda Accord LX, 4cy, auto. Front Disc Brakes / Rear Drum, 59,000 miles. I took her in and had the front disc brakes replaced (pad, etc.) While there the rear drums were turned (ground.) Immediately afterward a knocking sound developed on or near the rear passenger wheel. The noise only occurs when the brake pedal is pressed. The sound is similiar to a "clacking" or "clicking." The faster the speed when the brake are applied the faster the sound. The rear brakes shoes where replaced with new, the drum reground (both sides.) Swapped sides on the drums and wheel bearings (different times) NO CHANGE. Checked all the struts, bolts, etc. Wheel Cylinders and brake springs check out. Everything is tight and wear marks are not apparent in the drum or around the strut connections. So far I and two mechanics have over 10 hours chasing this demon. HELP!!!!
Jun 2, 2009 at 12:30 AM
