Ticking sound
219,634 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
JR47
  • 116 POSTS
I'm getting a ticking sound from the bottom of the engine, it sounds like metal hitting metal and to me it sounds like it's coming from inside the oil pan, I'm not sure that's just my guess. The sound speeds up and down with the rpm's and it does it no matter what gear its in even when idling. Any thoughts on what Could be going on here.
Mar 31, 2016 at 1:04 PM
HMAC300
  • 48,601 POSTS
might be a rod bearing, if you can disconnect on spark plug at a time and if it goes away it will tell you which cylinder to check. could be a piston though as well.
Apr 1, 2016 at 12:14 AM
JR47
  • 116 POSTS
I did as you said but could still hear the noise. Is it possible that something is hitting the inside of the oil pan? When I started it the noise was gone but after about 3 minutes it came back.
Apr 1, 2016 at 9:07 AM
HMAC300
  • 48,601 POSTS
it cold be something like a timing chain tensioner making the noise sounding like it's coming from pan. best case here is to have this checked locally as we cannot give a good diagnosis for noises.
Apr 1, 2016 at 9:14 AM
JR47
  • 116 POSTS
I found the problem the torque converter cover wasn't placed on it right. Thanks for replying
Apr 1, 2016 at 10:08 AM
HMAC300
  • 48,601 POSTS
obviously this has been worked on and you omitted that so it makes us hard to guess on stuff just happening.
Apr 1, 2016 at 11:30 PM
JR47
  • 116 POSTS
First of all I didn't do any work on this car until it was brought to my attention ok. So don't jump to conclusions and say I caused the problem.
Apr 2, 2016 at 11:25 AM
HMAC300
  • 48,601 POSTS
I didn't say you caused the problem when we have to guess on noises we have to try cover every angle.
Apr 3, 2016 at 1:34 AM
