Power Steering Whine
HONDA TECH 1818
  • 536 POSTS
The o ring is about 2-5 dollars at the dealer. You will need a bottle of Honda powersteering fluid also. You can do it yourself it's not hard at all. All you need to do is found the powersteering pump and remove the 10mm bolt and the black inlet joint at the front of the pump and replace the o ring. (When you remove the inlet joint use a cloth to catch some of the fluid)
Monday, January 7th, 2019 AT 11:10 AM (Merged)
ADH601
  • 2004 HONDA ACCORD
  • 6 CYL
  • FWD
  • 61,000 MILES
I have a 2004 Honda Accord with the 6 cyl. The power steering pump makes a lot of noise when cold, but the pump still works fine. After inspecting the pump I found no leaks and the fluid level is at full. I did notice that the hose comming from the top of the pump has some oily build up at one of the connection joints. My thouhgt is that there is small leak that allows air into the system. Once the engine warms up and the pressure builds the air is removed and the noise goes away. Should I replace this hose? Can this hose be repaired?
F4I_GUY
  • 3,302 POSTS
Sounds like your low pressure hose, if so then yes it can be replaced. If you see oily residue on it, it may have a very small leak. I would definately replace it and bleed the steering system of any remaining air afterwards.
DABLCKPRL
The problem is a very simple to fix. The O-Ring that connects one hose to the P/S is bad, it has to be replace. The Honda part number is P/N 91345-RDA-A01 ...
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
The above link is a guide to help u change it.. it takes like 2minutes and u are set...
The problem as stated above is a leak, air is coming in by the O-ring not doing its proper job. Overall you need the O-ring, which runs about $1.5 from Honda dealerships and Honda P/S fluid, about $3 for a bottle.
This is a $4 job not a $150+ as most dealerships charge.
Monday, January 7th, 2019 AT 11:11 AM (Merged)
ALZALLC
  • 5 POSTS
Looks like I have the same problem. I replaced the O-ring recommended by dablckprl but it didn't help. There is a leak in the pressure hose comming from the top of the power steering pump. The lower hose is a return hose only.
Looks like I need to replace the p/s pressure hose which is a lot more complicated? Do you think that I should also replace the pump itself?
DTHOMA
Thanks dablckprl for the link to the service bulletin. I have a 2005 V6 Accord 105k miles with the same noise problem when I first start my car in the mornings and was able to fix it by replacing the O-ring.
TRIPNOTIZED
I live in Brooklyn, NY and I need the O ring replaced on the steering pump in my accord. I have the O ring, just don't have the tool to replace it. If anyone wants to do it for me let me know, we will agree on the price.
CARIJEREMY2
  • 2004 HONDA ACCORD
  • 6 CYL
  • 175,000 MILES
I took it to different mechanics. 1 said it was a simple o-ring, the other said the whole pump as they cannot order separate parts. The car wines when cold but stops after it is warm. There is fluid on the reservore and needed to be filled. I dont know what to do
  • 109,896 POSTS
Does the noise go away when the PS fluid is full?
SATURNTECH9
  • 30,869 POSTS
So where is it leaking?Are you sure the rack and pion isnt leaking into the rack boots?
CARIJEREMY2
We added more fluid. We are going to change the o ring outside the pump first to see if that helps
