Power steering leaks
200,000 MILES
J RUDF
my power steering leaks when i cut my air conditioner on. I replaced the reservoir with a new one, but it happened again today. It stiffens up also when i turn wit the air conditioner on. Is my power steering pump the problem?
Nov 3, 2016 at 7:16 AM
JIS001
  • 3,412 POSTS
To check to see if the pump is bad, while parked turn the wheel left and right. If it is hard to turn then raise the rpm's to around 3000. If the steering gets better then your power steering pump is bad.
Nov 3, 2016 at 11:10 AM
J RUDF
The pump was bad so it was replaced thanks! I will keep in touch
Dec 9, 2016 at 1:19 PM
  • 55,746 POSTS
Glad you could get it fixed please use 2CarPros.com anytime we are here to help
Best, Ken
Dec 10, 2016 at 3:38 AM
