2005 Honda Accord 2005 accord ect sensor
KEVINEDWARDSNP
  • 5 POSTS
Electrical problem
2005 Honda Accord 4 cyl Front Wheel Drive Automatic 42K miles
I took my well cared for 2005 accord to the shop as the engine light came on. I was charged upfront $89.00 just to check for the problem (diagnostic)with the computer. Then they said I needed a new ECT sensor and subharness for $480.00 . Does this sound right? Is there any warranty of other recourse. This seems very steep. Are they ripping me off?
Kevin
Apr 30, 2008 at 11:43 AM
BLACKOP555
  • 10,386 POSTS
89 for a diagnostic fee!?!?!?!? autovalue does for free!
what is the exact code that is showing up ?
post it back so i can help you better to know if they are lying or what.
Apr 30, 2008 at 2:59 PM
KEVINEDWARDSNP
  • 5 POSTS
They gave me an estimate on paper and it says P0128. ECT sensor and harness fault.
Kevin
May 1, 2008 at 4:29 AM
BLACKOP555
  • 10,386 POSTS
first thing to do is always check the coolant level, if that is good check the cooling fan make sure its no overcooling, if it is cooling too much from a faulty switch the ECT will register a lower degree then the switch causing the code.
if thats not it then your ECT *engine coolant temp sensor or engine temp sensor* may be bad or the IAT sensor may be bat IAT=intake air temp sensor.
if those are not the remedy then maybe you have a bad thermostat.
May 1, 2008 at 11:13 AM
KEVINEDWARDSNP
  • 5 POSTS
I checked and it looks like I need a new sensor. Is that cost legit? It sound very high.
May 2, 2008 at 12:35 AM
BLACKOP555
  • 10,386 POSTS
the sensor should be no more then 80 bucks for a new one, you shouldnt need a harness..
May 2, 2008 at 8:35 AM
KEVINEDWARDSNP
  • 5 POSTS
Thanks for the reply. One more question. How long should it take to install this sensor?
May 3, 2008 at 1:04 PM
BLACKOP555
  • 10,386 POSTS
10 minutes, but dont expect them to hurry, expect a 30 min. fee.
May 4, 2008 at 1:54 AM
KEVINEDWARDSNP
  • 5 POSTS
I would like to do this myself. I can not locate the ECT sensor. Where is it? It is ECT#1 correct? Thanks, Kevin
May 12, 2008 at 4:58 AM
BLACKOP555
  • 10,386 POSTS
cant find a diagram on it sorry, look around the manifold and throttle body, even near lower radiator hose. try finding a pictureo nline and looking for it.
May 12, 2008 at 9:04 AM
CUP1981
  • 133 POSTS
for future reference the ECT is also called the radiator fan switch. It's located right next to the lower radiator hose.
May 2, 2011 at 2:44 AM
