2004 Honda Accord wobbles at 65
2004 HONDA ACCORD
ATM3535
Shakes or Wobbles problem
2004 Honda Accord 6 cyl Front Wheel Drive Manual 43xxx miles
Hello, i have an accord that is very smooth running accept for when i get to around 65mph. The steering wheel doesn't shake at all, neither does the brakes. Its just the car vibrates very rapidly around these speeds. You can see the dash bouncing. Have any ideas? i just bought it so i already had the dealer balance and rotate the tires twice and it still is doing it. Would a alignment do the trick? Maybe something with the suspension parts? TIA
Nov 18, 2008 at 11:05 AM
  • 31,937 POSTS
HI there,
If the vibration is purely body related it will be in the rear wheels, tyres or suspension, have all this checked carefully and they should find the problem, make sure that they check the rear wheel alignment as well.
mark (mhpautos)
Nov 18, 2008 at 11:24 AM
