2003 Honda Accord Window Switch Issue
SUNITHS
Interior problem
2003 Honda Accord 6 cyl Two Wheel Drive Automatic
Using the master switch, I can only lower the driver side rear window (cannot raise it from master switch). However I can operate that particular window fine (up and down) from the switch located in that door.
All the other windows work fine using the master switch and their respective individual switches. What seems to be the problem? Is it the Master Switch itself?
Mar 19, 2010 at 7:08 AM
KHLOW2008
  • 41,812 POSTS
Hi suniths,
It can be the master switch or the door switch that is faulty.
To test if it is the door switch, unplug the passenger side door switch for testing on the driver side.
Mar 20, 2010 at 8:27 PM
